[vcf-midatlantic] Is a TRS-80 Videotex Terminal functionally usable?
Kelly Leavitt
kelly at catcorner.org
Fri Feb 18 16:27:47 UTC 2022
I should work fine (slow, low res) as a text terminal. I used one at 300 baud to connect to compuserve and GENIE in the 80s.
________________________________
From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org> on behalf of Joseph Giliberti via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Sent: Friday, February 18, 2022 11:09 AM
To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Cc: Joseph Giliberti <kd2dhp at gmail.com>
Subject: [vcf-midatlantic] Is a TRS-80 Videotex Terminal functionally usable?
Greetings!
A friend of mine has a TRS-80 Videotex Terminal, which seems to be a very
limited CoCo1, intended solely for use with dial-up services which no
longer exist.
Other than being a display piece, is there any way of actually using it?
Could it dial in to a modem BBS?
Thanks!
Joe Giliberti
