[vcf-midatlantic] Is a TRS-80 Videotex Terminal functionally usable?
Dave McGuire
mcguire at neurotica.com
Fri Feb 18 16:31:53 UTC 2022
Wow, yuck. So really not worth it unless NAPLPS is involved.
-Dave
On 2/18/22 11:25, Dave Shevett wrote:
> Yep - check out that video i linked. It's tricky because the text
> resolution is 32x15. Not exactly a standard.
> -d
> On Fri, Feb 18, 2022 at 11:20 AM Dave McGuire via vcf-midatlantic
> <vcf-midatlantic at lists.vcfed.org> wrote:
>> Hey there Dave. So it will actually speak plan ASCII without
>> starting up the NAPLPS protocol, to make a (pretty crappy) plain terminal?
>> -Dave
>> On 2/18/22 11:18, Dave Shevett via vcf-midatlantic wrote:
>>> It looks like you can dial up with straight ASCII communication
>>> directly over the serial port (which'll require a DIN to RS232 cable).
>>> https://www.youtube.com/watch?v=o_rkEoQ803k
>>> There's an online BBS that the folks on /r/retrobattlestations use for
>>> testing / dialup access like this, you should be able to connect to it
>>> and chat with the world :)
>>> https://bbs.fozztexx.com/
>>> Getting 'videotex' working will be challenging, I don't know of an
>>> existing provider that will give you that experience.
>>> On Fri, Feb 18, 2022 at 11:10 AM Joseph Giliberti via vcf-midatlantic
>>>> Greetings!
>>>> A friend of mine has a TRS-80 Videotex Terminal, which seems to be a very
>>>> limited CoCo1, intended solely for use with dial-up services which no
>>>> longer exist.
>>>> Other than being a display piece, is there any way of actually using it?
>>>> Could it dial in to a modem BBS?
>>>> Thanks!
>>>> Joe Giliberti
>> Dave McGuire, AK4HZ
>> New Kensington, PA
Dave McGuire, AK4HZ
New Kensington, PA
