[vcf-midatlantic] Add-on card edge fingers for mock S-100 boards
Jonathan Chapman
lists at glitchwrks.com
Mon Jan 10 23:29:57 UTC 2022
As Mike suggested, just use proper prototyping boards. The difference in cost is minimal, especially if you troll eBay and such looking for NOS/lightly used Vector boards. They will also hold up a *lot* better than a homebrew solution.
If there aren't any for reasonable money available right now, email me directly and I'll dig one up for you!
Thanks,
Jonathan
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Monday, January 10th, 2022 at 17:51, Mike Loewen via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> On Mon, 10 Jan 2022, Joseph Giliberti via vcf-midatlantic wrote:
> > I've been making basic design plans for my 8080- based homebrew computer.
> > I want to build the system using the S-100 standard so that I could
> > potentially add on commercially-built boards later.
> > I've decided on wire-wrap board construction since the connections are
> > solid and resistant to damage or corrosion. Plus it just looks so damn
> > cool!
> > I figure I can use plain perfboard to make the cards, but I need some way
> > of grafting card-edge fingers onto the board and wrap them into the
> > circuit, allowing me to connect to card to a standard S-100 backplane.
> > Is there a premade part in existence to accomplish this, of will this be a
> > project in and of itself?
> Joe:
> You might want to obtain some S-100 prototyping boards, such as this one:
> http://q7.neurotica.com/Oldtech/S100/Vector8800V-L.jpg
> Modern versions are discussed, here:
> http://www.s100computers.com/My System Pages/Prototype Board/Prototype Board.htm
> Mike Loewen mloewen at cpumagic.scol.pa.us
> Old Technology http://q7.neurotica.com/Oldtech/
