[vcf-midatlantic] Minerva's Machine - women and computing
Herb Johnson hjohnson at retrotechnology.info
Fri Jan 14 16:46:26 UTC 2022
> George Washington University has it in their library which is over in the
> City. West Chester PA has it, WVU. One in Allentown as well.
> If you can't find it anywhere I might be able to reach out to GWU about
> what it takes for a non-student to check it out ...
There's something called "inter-library loan" that most local public
libraries and universities support. Typically your local tax dollars pay
for the library services you get (once you register). Contact your local
library system for details. They will perform the loan request, obtain
the item for your pickup, and return it when you return the item to the
local library.
Regards, Herb Johnson
or try later herbjohnson AT comcast DOT net
