[vcf-midatlantic] S-100 protoboards
Jeff Galinat
jgalinat at gmail.com
Fri Jan 14 20:59:05 UTC 2022
Jonathan & Herb,
Thanks for clarifying. I knew the pin to pin spacing was .125” but I
thought the Altair was the only system that used the narrow row spacing. I
learned something today.
Regards,
Jeff
On Fri, Jan 14, 2022 at 11:31 AM Jonathan Chapman via vcf-midatlantic <
> > It was my understanding that only the Altair backplane had a different
> row
> > spacing for it's connectors. Everything that I have seen since (IMSAI,
> > Ithaca, TEI, CompuPro, Cromemco) used the same .250 row spacing.
> The Byte Shop BYT-8 and Polymorphic Poly-88 both use the narrower spacing
> too. I don't know if later Polymorphic systems do too. There are probably
> others. Haven't checked on my TDL stuff.
> Thanks,
> Jonathan
