[vcf-midatlantic] OpenVMS 6.2 DNS Support
VAXman at tmesis.org VAXman at tmesis.org
Thu Jan 20 22:08:17 UTC 2022
Christian Liendo via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
writes:
>Can someone help me with this. Does OpenVMS 6.2 support DNS/BIND?
>I wm being told the following:
>"Correct the OpenVMS 8.4 support the DNS we are running OpenVMS
>V6.2-1H3"
>"It is running older TCP/IP from Digitial call UCX"
>I looked up UCX and I see a DNS config, but I cannot tell if it is
>supported in a newer or older version.
>Does anyone know?
Yes.  Thanks for asking. :P
Get the output of this command for starts.
$ TCPIP SHOW VERSION
