[vcf-midatlantic] OpenVMS 6.2 DNS Support
Christian Liendo
cliendo at gmail.com
Thu Jan 20 22:13:14 UTC 2022
> Yes. Thanks for asking. :P
Well I haven't seen you on here for a while.
Thanks for responding.
I don't have access to the box but I will ask.
On Thu, Jan 20, 2022, 5:10 PM Brian Schenkenberger via vcf-midatlantic <
> Christian Liendo via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
> writes:
> >Can someone help me with this. Does OpenVMS 6.2 support DNS/BIND?
> >I wm being told the following:
> >"Correct the OpenVMS 8.4 support the DNS we are running OpenVMS
> >V6.2-1H3"
> >"It is running older TCP/IP from Digitial call UCX"
> >I looked up UCX and I see a DNS config, but I cannot tell if it is
> >supported in a newer or older version.
> >Does anyone know?
> Get the output of this command for starts.
> $ TCPIP SHOW VERSION
