[vcf-midatlantic] Recovery of RD53 image data
David Riley fraveydank at gmail.com
Tue Jan 25 18:30:42 UTC 2022
On Jan 25, 2022, at 1:11 PM, David Gesswein via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> I have a bunch of tapes on the to read stack. I think I got the drive
> working but was running into the tape sticking problem. On the todo is
> buying/making a tape baker to try to archive the tapes. I also got a SCSI
> version of the drive which should make it easier to create an image.
FWIW on the tape baker, Chuck Guzis always used to recommend a 25W bulb in a cardboard box for a few days.  Should be easy enough if you have any old 25W bulbs still kicking around.
- Dave
-------------- next part --------------
A non-text attachment was scrubbed...
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <https://lists.vcfed.org/pipermail/vcf-midatlantic/attachments/20220125/39320ddc/attachment.sig>
