[vcf-midatlantic] VCF East Related
CT chesapeaketechie at gmail.com
Sun Jan 30 16:52:23 UTC 2022
Hi Jason - I would find this interesting. I have a couple of old
Televantage computer based PBX’s - who I believe were made by the same
folks who owned Comdial (Artisoft / Vertical).
Regards,
  Eric
On Sun, Jan 30, 2022 at 7:51 AM Jason Perkins via vcf-midatlantic <
> Would people be interested in a PBX exhibit?
> I have a large Comdial pbx, with computer voicemail / auto attendant, which
> I could hook up to and show how call flow and system programming work...
> Would this be on the PSTN, or C*Net?
> Do you have the ability to hand off a PRI?
> And finally, is this something people would find interesting?
> This is a bit new for a VCF, circa 1997.
> -J
> On Sat, Jan 29, 2022 at 7:47 PM Jameel Akari via vcf-midatlantic <
> > If there was wired Ethernet providing general Internet access, I would
> use
> > it.
> > If not, I bodge something together with my phone and my Mac like we’ve
> > done the past couple years.
> > Jameel Akari
> > > On Jan 29, 2022, at 11:46 AM, Martin Flynn via vcf-midatlantic <
> > > So the usual suspects from both CDL and VCF have been upgrading the
> > network at Camp Evans.   As noted by Jeff B, we extended single-mode
> fiber
> > to 9032 and have the access points and a 48 port PoE switch staged to
> > deploy.
> > > Question for the folks that will be exhibiting in or using 9032A for
> VCF
> > East:   Will anyone need telephone lines (analog / ISDN) or wired
> Internet
> > connections during VCF East in the big room?
> > > Knowing ahead of time will let us prioritize the work better
> > > Martin Flynn
> Jason Perkins 313 355 0085 Sent from my iPhone
