[vcf-midatlantic] VCF East Related
Jameel akari
jakari at bithose.com
Mon Jan 31 01:31:00 UTC 2022
I’d also find it interesting. A PBX like this is definitely not contemporary business telephony - it’s pretty vintage if you actually use it.
I have a AT&T Merlin Legend which is well past vintage age. I’d haul it down for VCF East if you wanted to try and figure out trunking (has at least one ISDN port and I have a T1 line card too.) Mostly it exists to ring our stylish vintage telephone collection. :)
Jameel Akari
> On Jan 30, 2022, at 11:52 AM, CT via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> Hi Jason - I would find this interesting. I have a couple of old
> Televantage computer based PBX’s - who I believe were made by the same
> folks who owned Comdial (Artisoft / Vertical).
> Regards,
> Eric
>> On Sun, Jan 30, 2022 at 7:51 AM Jason Perkins via vcf-midatlantic <
>> Would people be interested in a PBX exhibit?
>> I have a large Comdial pbx, with computer voicemail / auto attendant, which
>> I could hook up to and show how call flow and system programming work...
>> Would this be on the PSTN, or C*Net?
>> Do you have the ability to hand off a PRI?
>> And finally, is this something people would find interesting?
>> This is a bit new for a VCF, circa 1997.
>> -J
>> On Sat, Jan 29, 2022 at 7:47 PM Jameel Akari via vcf-midatlantic <
>>> If there was wired Ethernet providing general Internet access, I would
>> use
>>> it.
>>> If not, I bodge something together with my phone and my Mac like we’ve
>>> done the past couple years.
>>> Jameel Akari
>>>> On Jan 29, 2022, at 11:46 AM, Martin Flynn via vcf-midatlantic <
>>>> So the usual suspects from both CDL and VCF have been upgrading the
>>> network at Camp Evans. As noted by Jeff B, we extended single-mode
>> fiber
>>> to 9032 and have the access points and a 48 port PoE switch staged to
>>> deploy.
>>>> Question for the folks that will be exhibiting in or using 9032A for
>> VCF
>>> East: Will anyone need telephone lines (analog / ISDN) or wired
>> Internet
>>> connections during VCF East in the big room?
>>>> Knowing ahead of time will let us prioritize the work better
>>>> Martin Flynn
>> Jason Perkins 313 355 0085 Sent from my iPhone
