[vcf-midatlantic] EASY 6502
Douglas Crawford touchetek at gmail.com
Thu Jun 2 01:25:04 UTC 2022
Its a good one. I used that in the 6502 assembly class
a few VCFs ago to demonstrate operational code.
I recommend it too!
On 5/31/2022 9:38 AM, Jeffrey Brace via vcf-midatlantic wrote:
> On Tue, May 31, 2022 at 7:54 AM Christian Liendo via vcf-midatlantic <
> vcf-midatlantic at lists.vcfed.org> wrote:
>> Someone wrote a small document on 6502 assembly and I figured someone
>> here might enjoy reading this.
>> http://skilldrick.github.io/easy6502/
> Very cool Christian! Thanks for sharing! Having it on a website like this
> with Javascript makes it easy to learn without needing to find an assembler
> that works with the lessons. And easy to follow lessons! I may be inspired
> to finally follow through on learning 6502 this time ;) I did try going
> through Jim Butterfield's book, but stopped.
