[vcf-midatlantic] Need help with audio processing from VCF West 6 (2003)
Jeffrey Brace
jeffrey at vcfed.org
Wed Jun 22 12:00:00 UTC 2022
Kay Savetz was able to successfully recover most of the talks from VCF 6
2003 with the help of Clay Cowgill.
There are still some talks that are troublesome, so we are looking someone
who is an expert at magically transforming audio issues.
The issue as described to me is as follows:
The audio is in WAV format, recorded poorly. Needs filtering, EQ, and
magic. Audio levels range from normal to extremely low. Some of the audio
levels seem to fade in and out even within the same sentence. Noise
includes a 60hZ hum, and sometimes buzzy static — sometimes the static is
significantly louder than the voice. Speaker sometimes too far away from
the microphone. In summary, the audio ranges from “not bad, but I wish
that buzzing would go away” to “what? what did they say?”
If you know of someone that can help, then please let me know.
Thanks!
Jeff Brace
VCF National Board Member Chairman & Vice President
Vintage Computer Festival East Showrunner
Vintage Computer Federation is a 501c3 charity
https://vcfed.org/ <http://www.vcfed.org/>
