[vcf-midatlantic] VCF East 2022 - Pre Event Survey
David Gesswein
djg at pdp8online.com
Mon Mar 21 00:58:58 UTC 2022
On Sun, Mar 20, 2022 at 04:13:13PM -0400, Jeffrey Brace via vcf-midatlantic wrote:
> OK. According to Rick:
> "The survey machine is working correctly.
> For Q7, you can only use each number (1,2,3,4,5) once, because you are
> asked to RANK the five choices. If you try to rank two things with the
> same value then it will correctly clear one of the previous entries.
Tough survey, need to actually read the instructions :-).
