[vcf-midatlantic] VCF East 2022 - Pre Event Survey
Jeffrey Brace jeffrey at vcfed.org
Mon Mar 21 12:01:44 UTC 2022
On Sun, Mar 20, 2022 at 8:59 PM David Gesswein via vcf-midatlantic <
> On Sun, Mar 20, 2022 at 04:13:13PM -0400, Jeffrey Brace via
> vcf-midatlantic wrote:
> > OK. According to Rick:
> > "The survey machine is working correctly.
> > For Q7, you can only use each number (1,2,3,4,5) once, because you are
> > asked to RANK the five choices.  If you try to rank two things with the
> > same value then it will correctly clear one of the previous entries.
> Tough survey, need to actually read the instructions :-).
LOL!
