[vcf-midatlantic] VCF East Clinic kudos
Neil Cherry ncherry at linuxha.com
Sun May 1 17:07:19 UTC 2022
On 4/30/22 18:44, Jonathan Chapman via vcf-midatlantic wrote:
>> Did someone just goof around and see how much fresh solder they could suck
>> up into the thing?
> Heh, Crawford is just picking on himself, he hadn't used a Hakko before and didn't know you try to keep the tip (metallic/flux) dry -- that's why they recommend the brass wool cleaner, it scrapes it clean. He dunked the tip in flux as one does with a soldering iron, to clean it. The Hakko runs at 750 *F and basically instantly carbonized it into a plug. Fortunately, CDL has a numbers drill set and we used one of the little ones to clean it out. As luck would have it, the proper tool for that (a small drill in a pin vise) got left at the shop!
> Thanks,
> Jonathan
BRASS WOOOL, EEEEEK!
Linux Home Automation         Neil Cherry       ncherry at linuxha.com
http://www.linuxha.com/                         Main site
http://linuxha.blogspot.com/                    My HA Blog
Author of:    	Linux Smart Homes For Dummies
