[vcf-midatlantic] VCF East Clinic kudos
Herb Johnson hjohnson at retrotechnology.info
Thu May 5 00:32:13 UTC 2022
[Discussion about Jonathan's S-100 workshop in the CDL facility.]
I spent time in Jon's workshop, mostly observing. I also enjoyed seeing
the IMSAIs in repair. And it's good to see people learning to build kits
from components.
Jon and I tag-teamed on one IMSAI fix. He was looking up details on a
front-panel signal that wasn't pulsing; but could not find an early
IMSAI schematic. While he was looking, I reverse-engineered the circuit
to trace it backwards. He found the problem from the schematic, just as
I traced it back, to the same one-shot 74121. Replacing it solved the
problem; apparently 40-year-old monostables tend to fail, Jon said at
the time.
There were a number of people in the workshop, exercising their
collective knowledge of these early vintage computers. It was good to
see them all, not just the S-100 machines. And it should be noted: there
was a nice exhibit of early S-100 computers, thanks to Mike Loewen.
I'm certainly in favor of another workshop devoted to more 1970's
computers, if not only S-100 computers. If it's done during a swapmeet,
I suggest not much work will get done in the morning, people will be
swapping. So that eats into a day of repair.
Regards, Herb Johnson
sometimes called "Dr. S-100"
or try later herbjohnson AT comcast DOT net
