[vcf-midatlantic] VCF Repair workshops and keeping the costs of HVAC down
Jeffrey Brace jeffrey at vcfed.org
Wed May 11 12:54:22 UTC 2022
On Wed, May 11, 2022 at 8:47 AM Jonathan Chapman via vcf-midatlantic <
> I'd shut the heat off and left the doors open during VCF East, not sure if
> it was turned back on at some point during the event. Figured with the nice
> weather, there was no sense in burning gas! Is that acceptable for when the
> weather is nice?
I'd say if the heat was off, then that was fine, because there was no extra
cost. But in the future there will be a locked down temperature control
which we can't control, so turning off the heat and leaving the doors open
won't be possible once they install a Trane XL824 smart thermostat.
> Thanks,
> Jonathan
> ------- Original Message -------
> On Wednesday, May 11th, 2022 at 08:43, Jeffrey Brace via vcf-midatlantic <
> > VCF makes use of the Makerspace and classroom in 9059 during our repair
> > workshops.
> > CDL just cut the checks to cover the first quarter gas bills for their
> > Makerspace (per the IA lease agreement). The total came to $932.00. The
> > cost per therm has gone up.
> > During workshops, we need to keep the exterior doors closed to keep the
> > heat and A/C in the building.
> > How we can help: not allowing the doors to be held open for extended
> > periods of time. Moving things in and out is fine, but keeping it open
> for
> > extended periods of time increases the HVAC costs.
> > Thank you for your cooperation.
> > Jeff Brace
> > VCF National Board Member Chairman & Vice President
> > Vintage Computer Festival East Showrunner
> > Vintage Computer Federation is a 501c3 charity
> > https://vcfed.org/ http://www.vcfed.org/
