[vcf-midatlantic] VCF Repair workshops and keeping the costs of HVAC down
Martin Flynn
maflynn at theflynn.org
Wed May 11 13:19:00 UTC 2022
Smart thermostat has both internal and external temp sensors, do it’s a nice day, we can pull in outside air.
Our SME , Neil Cherry is taking care of the building automation.
We are actually looking to scavenge the waste heat from the IT equipment in the winter to scrape up some savings
Martin
Sent from my iPhone
> On May 11, 2022, at 9:02 AM, Jonathan Chapman via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>> Perhaps an arduino with a temperature sensor could data log mean
>> temperatures every hour for a month to verify the temperature ranges.
> I'd imagine Martin can pull temperatures from some of the equipment in the rack: either a server's internal environmental monitors, or a separate room temperature monitor associated with a UPS or something.
> I'd assume he's already doing that, in fact :P Monitoring and recording parameters is fun.
> Thanks,
> Jonathan
