[vcf-midatlantic] Help shipping ASR-33 from Allentown
William Sudbrink wh.sudbrink at gmail.com
Thu May 12 20:42:55 UTC 2022
PDF page 91 shows the H-Plate.  While it will probably stay in place if the
typing unit is properly screwed down, if you lose it, you will be very
unhappy.  It is spring loaded, so it can pop out.
-----Original Message-----
From: vcf-midatlantic [mailto:vcf-midatlantic-bounces at lists.vcfed.org] On
Behalf Of David Gesswein via vcf-midatlantic
Sent: Thursday, May 12, 2022 4:34 PM
To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Cc: David Gesswein <djg at pdp8online.com>
Subject: Re: [vcf-midatlantic] Help shipping ASR-33 from Allentown
On Thu, May 12, 2022 at 04:22:11PM -0400, William Sudbrink via
vcf-midatlantic wrote:
> Make absolutely sure that the printing unit is screwed down.
> Otherwise you will end up with a shattered plastic cover.
> The printing unit "floats" in normal operation.  Also, have the
> shipper remove the H-Plate and put it in an envelope or something so
> that it does not get lost.
Manual talks about this some.
http://www.pdp8online.com/pdp8cgi/query_docs/tifftopdf.pl/pdp8docs/telet1_1.
pdf
Set page 69 and 86 of pdf.
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
