[vcf-midatlantic] Simple Commodore drive question
Dean Notarnicola dnotarnicola at gmail.com
Tue May 17 19:05:07 UTC 2022
Gotcha. Sorry for the confusion, but hopefully that clears things up!
On Tue, May 17, 2022 at 3:04 PM Kelly Leavitt via vcf-midatlantic <
> Dean,
> That's not my definition of straight through. Straight through means 1 to
> 1, 2 to 2, etc. Like Sentrytv said.
> I can see it from your point of view, but that's not what I meant.
> ________________________________
> From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org> on behalf
> of Dean Notarnicola via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
> Sent: Tuesday, May 17, 2022 2:45 PM
> To: Sentrytv <sentrytv at yahoo.com>
> Cc: Dean Notarnicola <dnotarnicola at gmail.com>; vcf-midatlantic <
> Subject: Re: [vcf-midatlantic] Simple Commodore drive question
> Think about two din connectors facing away from each other. If you ran a
> wire straight-through from pin 5 on one side, it would go to pin 1 on the
> other side.
> On Tue, May 17, 2022 at 2:44 PM Sentrytv <sentrytv at yahoo.com> wrote:
> > So this may be a stupid question but if you wire cable pin to pin, does
> > not not mean straight through?
> > Like, pin 1 to pin 1, pin 2 to pin  2, etc..?
> > Sent from:
> > My extremely complicated, hand held electronic device.
> > > On May 17, 2022, at 2:34 PM, Dean Notarnicola via vcf-midatlantic <
> > > Not straight through. See the following link for reference:
> > > https://www.lemon64.com/forum/viewtopic.php?t=56401&start=0
> > >> On Tue, May 17, 2022 at 12:34 PM Kelly Leavitt via vcf-midatlantic <
> > >> Is there anything special about the serial disk drive cable for the
> > 1541s
> > >> or will any straight through 6 pin DIN work?
> > >> I have several drives but I don't seem to have any of the cables.
> > >> Thanks,
> > >> Kelly
