[vcf-midatlantic] Simple Commodore drive question
Dean Notarnicola
dnotarnicola at gmail.com
Wed May 18 18:48:20 UTC 2022
Exactly, thanks for the clarification!
On Wed, May 18, 2022 at 12:35 PM Jason Perkins <perkins.jason at gmail.com>
wrote:
> If we want to be pedantic, I think Dean is thinking of a rollover cable :)
> (12345 --> 54321)
> -J
> On Tue, May 17, 2022 at 12:05 PM Dean Notarnicola via vcf-midatlantic <
> vcf-midatlantic at lists.vcfed.org> wrote:
>> Gotcha. Sorry for the confusion, but hopefully that clears things up!
>> On Tue, May 17, 2022 at 3:04 PM Kelly Leavitt via vcf-midatlantic <
>> > Dean,
>> > That's not my definition of straight through. Straight through means 1
>> to
>> > 1, 2 to 2, etc. Like Sentrytv said.
>> > I can see it from your point of view, but that's not what I meant.
>> > ________________________________
>> > From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org> on
>> behalf
>> > of Dean Notarnicola via vcf-midatlantic <
>> > Sent: Tuesday, May 17, 2022 2:45 PM
>> > To: Sentrytv <sentrytv at yahoo.com>
>> > Cc: Dean Notarnicola <dnotarnicola at gmail.com>; vcf-midatlantic <
>> > Subject: Re: [vcf-midatlantic] Simple Commodore drive question
>> > Think about two din connectors facing away from each other. If you ran a
>> > wire straight-through from pin 5 on one side, it would go to pin 1 on
>> the
>> > other side.
>> > On Tue, May 17, 2022 at 2:44 PM Sentrytv <sentrytv at yahoo.com> wrote:
>> > > So this may be a stupid question but if you wire cable pin to pin,
>> does
>> > > not not mean straight through?
>> > > Like, pin 1 to pin 1, pin 2 to pin 2, etc..?
>> > > Sent from:
>> > > My extremely complicated, hand held electronic device.
>> > > > On May 17, 2022, at 2:34 PM, Dean Notarnicola via vcf-midatlantic <
>> > > > Not straight through. See the following link for reference:
>> > > > https://www.lemon64.com/forum/viewtopic.php?t=56401&start=0
>> > > >> On Tue, May 17, 2022 at 12:34 PM Kelly Leavitt via vcf-midatlantic
>> > > >> Is there anything special about the serial disk drive cable for the
>> > > 1541s
>> > > >> or will any straight through 6 pin DIN work?
>> > > >> I have several drives but I don't seem to have any of the cables.
>> > > >> Thanks,
>> > > >> Kelly
> Jason Perkins 313 355 0085 Sent from my iPhone
