[vcf-midatlantic] ZX81/TS1000 with a modern TV
Jeff S jsalzman at gmail.com
Mon May 23 20:31:47 UTC 2022
The K cursor is normal, and standard. The ZX81 does not have any kind of
intro or status boot screen. If you're seeing the K, then unless there's
something wrong with the keyboard, you should be able to see any numbers
you type.
On Mon, May 23, 2022, 4:21 PM Bob Shuster via vcf-midatlantic <
> So I have two (2) Sinclair ZX81s (US version - one is still an unbuilt
> kit), and three (3) Timex-Sinclair 1000s.  I’ve connected them to a TV
> using an RCA-coax adapter and tuned to the correct channel, but I get a
> grey screen with the “K” cursor visible.  I’m unable to get past this.
> This is for all four units.  They seem to tune in white momentarily then
> switch to fuzzy grey - with the “K” still visible.  This was both on a
> large 4K OLED set and a small HD LED TV, and I suspect they are just too
> new to deal with the monochrome signal.  I don’t have a CRT TV to test
> with, just old monitors (which of course don’t have antenna connections.)
> Any advice?  I’m selling these, so I’m not getting into modding them, just
> want to confirm they’re working properly.
> Bob Shuster
