[vcf-midatlantic] Mylar Tape
Duane Craps DBC1964 at cox.net
Mon Mar 27 23:47:54 UTC 2023
Justin,
Thanks, I needed that
You're right. I was wrong on my mental math.
Still good for more than I'll ever punch.
On 3/27/2023 7:20 PM, Hopkins, Justin wrote:
> 4-1? Or 40-1?
> -----Original Message-----
> From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org> On Behalf Of Duane Craps via vcf-midatlantic
> Sent: Monday, March 27, 2023 6:59 PM
> To: Ethan Dicks via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
> Cc: Duane Craps <DBC1964 at cox.net>
> Subject: Re: [vcf-midatlantic] Mylar Tape
> EXTERNAL EMAIL
> Ethan,
> The information for the DSI NC2400 punch life is:
> Paper 2,000,000 feet
> Mylar 50,000 feet
> So it's 4/1 ratio.
> So, if you're not punching 9.47 miles of mylar there should not be a problem.
> I always heard that mylar was harder on the punch but, did not know how long it would take.
> Other punches could be different.
> I attached a screenshot of my source.
> Duane
> On 3/27/2023 5:09 PM, Ethan Dicks via vcf-midatlantic wrote:
>> On Mon, Mar 27, 2023 at 4:52 PM Duane Craps via vcf-midatlantic
>> <vcf-midatlantic at lists.vcfed.org> wrote:
>>> There is cheap mylar punch tape on ebay.
>>> I bought a few rolls.
>>> https://urldefense.com/v3/__https://www.ebay.com/itm/392994905002?has
>>> h=item5b80525baa:g:tZoAAOSwJUdeZ5ki&amdata=enc*3AAQAHAAAAwFR15icY4IDj
>>> *2BA4FOlXLMgwfuFIMe0H469mNeza4GfAeNrqJoSs*2FrhwBRZCixi*2F32LY1xb6MIRp
>>> VSI5cL*2BeuVssl*2FRzQaEDPgvKxAeBI87jFxh9y4Y2QDSbyA3ISCNOZp5Ldeo6qKVEq
>>> JINjuprEJL6mVqCOPJ*2B8zBTVMjRqg7vtoAsmf6yNtJNxlwEXxbFz6s8uU*2FQgzGN2r
>>> vkeSzGXkLrD8DRtPblbW6JVsoO4DVBuaQOyTGH94e7F5Fd1ZrFY*2Bw*3D*3D*7Ctkp*3
>>> ABk9SR-ql88PkYQ__;JSUlJSUlJSUlJSUlJQ!!Ebr-cpPeAnfNniQ8HSAI-g_K5b7VKg!
>>> Khq2-BXxSYQtfj0YcUuMJJv1eXM5G_zU5VBWUVwX4lwdmS3qqaXK7VVqOZ616ssiSxb3M
>>> 6WdjYuCQmRjYvqYzmQuwVhl9k38L7OKrP0$
>> I have a roll of that which I think glued itself together.   I have
>> smaller rolls I haven't run yet because of wear on the punch.  Maybe
>> for 2-3 specific heavy-use programs, like a binloader.
>> Thanks for the tip.
>> -ethan
> DuaneCraps
> sdɐɹɔ ǝuɐnp
> This message and any attachments are intended only for the use of the addressee and may contain information that is privileged and confidential. If the reader of the message is not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any dissemination of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by e-mail and delete the message and any attachments from your system.
DuaneCraps
sdɐɹɔ ǝuɐnp
