[vcf-midatlantic] [off topic] - GaN USB chargers and temps
Neil Cherry
ncherry at linuxha.com
Wed Feb 21 22:40:20 UTC 2024
On 2/21/24 15:27, David Riley via vcf-midatlantic wrote:
> On Feb 21, 2024, at 2:57 PM, John Heritage via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
Other problem is your USB cables. You'll need the correct cable and the USB C cables
are complex and *USUALLY* only work in one direction (correct resistors on one connector
and not the other). I'm not an expert but this is one confusing protocol.
> Hard to say. If you smell the telltale smell of hot plastic, be worried.
++2 !!!
Linux Home Automation Neil Cherry kd2zrq at linuxha.com
http://www.linuxha.com/ Main site
http://linuxha.blogspot.com/ My HA Blog
Author of: Linux Smart Homes For Dummies KD2ZRQ
