[vcf-midatlantic] [off topic] - GaN USB chargers and temps
William Dudley
wfdudley at gmail.com
Thu Feb 22 01:46:03 UTC 2024
Electrolytic caps are not going to be happy with high temperatures.
Bill Dudley
This email is free of malware because I run Linux.
On Wed, Feb 21, 2024 at 2:58 PM John Heritage via vcf-midatlantic <
> Hey folks -
> Looking for some insight from the hardware inclined here.
> GaN USB chargers are touted as being able to deliver higher power in
> smaller form factors (I.e. charging a 65W USB device while the size of a
> “standard silicon” ~ 10-20W USB charger).
> I know on paper GaN can run a lot hotter successfully than silicon (>150C
> for example), but I’m wondering - when you have a GaN USB charger that runs
> pretty hot for long period of time, is it really safe? Aren’t there
> likely other components in the charger that don’t have the increased heat
> tolerance of GaN semiconductors?
> I’m asking as one of my GaN chargers gets hot enough to the point that I’d
> be really worried with a traditional PSU. It only happens if I had two
> devices attached that need a full charge - once they’re topped off or
> higher up in charge temperature is no issue.
> Thanks,
> John
