[vcf-midatlantic] A 4004 Based Microcomputer the Comstar System 4
Herbert Johnson hjohnson at retrotechnology.info
Thu Jan 11 22:46:40 UTC 2024
My description of the Comstar 4 product line was in error. Careful
reading of the ACM/NCC 1975 description by the company, says the
"compiler" was a device with keyboard and 32-character display, which
accepted "key per function" features of the PLC language, displayed the
entered statement, and accumulated the 4004 "compiled" instructions into
a 256-byte EPROM (likely an Intel 2708). Those ROMS operated the Comstar
4 controller which operated the application equipment as programmed.
Other Comstar 4 devices, provided diagnostic and testing of the
controller and its PLC program.
While the PLC language was claimed to be "FORTRAN-like", the document
deliberately explains that the compiler product (a machine, not a
FORTRAN or other program) is used on-site and avoids the need for some
remote computer to process (assemble or compile) some textual program.
I can imagine the difficulties Christian had, in trying to determine the
function and operation of the Comstar 4 "computer" and "programmer".
Especially years ago when knowledge of the 4004/40 was even more obscure.
My error goes to my point, that these very early 4-bt microprocessor
based products are difficult to interpret from a later view of computing
and microprocessor development and use.
Regards Herb Johnson
On 1/11/2024 2:57 PM, Herbert Johnson wrote:
> Apparently that Comstar 4, and certainly early use of the Intel 4004,
> are examples of industrialm controls. From Christian's documents, the
> Compstar System 4 was a replacement for ladder-logic or PLC (programmed
> logic) controllers for industrial control. The PLC program was
> cross-compiled on some mainframe or minicomputer running a FORTRAN
> program. That was a very common means of microprocessor programming in
> the early-mid 1970's. Gary Kildall ...
> produced FORTRAN assemblers and PL/M compilers for Intel's 8008 and
> 8080, for development of industrial applications.
Herbert R. Johnson, New Jersey USA
https://www.retrotechnology.com OR .net
or try later herbjohnson AT comcast DOT net
