[vcf-midatlantic] OT / APC AP9617 UPS network card reset
Jonathan Chapman
lists at glitchwrks.com
Sun Jan 14 20:36:15 UTC 2024
Be aware you may need a goofy cable. I had to make one up when resetting the management card in my old SmartUPS 1000RM after the original card died.
Thanks,
Jonathan
On Sunday, January 14th, 2024 at 15:25, Martin A. Flynn via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> The AP9617 card does not have a separate serial Interface and the
> pass-thru serial port on the SUA2200RMXL3U does not respond to the
> factory defaults....
> On 1/14/2024 3:18 PM, Jameel akari via vcf-midatlantic wrote:
> > I would try to re-configure via the UPS’s serial port first. Default username and password are usually apc / apc .
