[vcf-midatlantic] 2 PAL TVs needed for VCF East 2024
Hopkins, Justin Justin.Hopkins at broadridge.com
Thu Jan 18 20:07:16 UTC 2024
Well, if it can work, I can donate a TV for the cause….
It is a 30” TCL with all the same inputs as the one in the picture, but a corroded remote control (but you can still switch through the input modes using the buttons on the back of the TV)
If someone has a PAL computer they can test it out on, I can drop it off anywhere in Northern New Jersey.
Sent: Thursday, January 18, 2024 1:43 PM
To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Cc: Dean Notarnicola <dnotarnicola at gmail.com>; Hopkins, Justin <Justin.Hopkins at broadridge.com>
Subject: Re: [vcf-midatlantic] 2 PAL TVs needed for VCF East 2024
On Thu, Jan 18, 2024 at 11: 47 AM Hopkins, Justin via vcf-midatlantic <vcf-midatlantic@ lists. vcfed. org> wrote: Any idea on this one? https: //newjersey. craigslist. org/zip/d/haworth-sony-26-tv/7707457360. html It has the composite jacks. I
ZjQcmQRYFpfptBannerStart
This Message Is From an Unknown Sender
You have not previously corresponded with this sender.
ZjQcmQRYFpfptBannerEnd
On Thu, Jan 18, 2024 at 11:47 AM Hopkins, Justin via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org<mailto:vcf-midatlantic at lists.vcfed.org>> wrote:
https://newjersey.craigslist.org/zip/d/haworth-sony-26-tv/7707457360.html
I found the manual for this TV online and it says it supports NTSC. No mention of PAL.
https://www.sony.com/electronics/support/res/manuals/W000/W0005383M.pdf
Still possible it might work, just an undocumented feature.  For the price, there's no
harm in trying it out.  Since it has HDMI inputs, worst-case you just have to add a
PAL to HDMI converter, for example:
https://www.amazon.com/Converter-ABLEWE-Composite-Supporting-Blue-Ray/dp/B07RX69KR8
-ken
This message and any attachments are intended only for the use of the addressee and may contain information that is privileged and confidential. If the reader of the message is not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any dissemination of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by e-mail and delete the message and any attachments from your system.
