[vcf-midatlantic] OT / APC AP9617 UPS network card reset
Martin A. Flynn
maflynn at theflynn.org
Sat Jan 27 15:32:20 UTC 2024
Resolution: Fix was doing a processor reset in the SUA2200RMXL3U and
swapping the batteries on the 9617 card.
Cable and software are in the makerspace in case anyone from VCF runs
into the same issue.
Martin
On 1/14/2024 3:45 PM, Martin A. Flynn wrote:
> Using the factory DE-9 cable APC SKU 940-0024E on the UPS pass through
> port,
> Connecting with a Toughbook (real serial port, 2400 bps, 8 data bits,
> no parity, 1 stop bit, and no flow control).
> Ordered CR2032 coin cells on the off chance they are depleted from
> sitting on the shelf.
> Martin
> On 1/14/2024 3:36 PM, Jonathan Chapman via vcf-midatlantic wrote:
>> Be aware you may need a goofy cable. I had to make one up when resetting the management card in my old SmartUPS 1000RM after the original card died.
>> On Sunday, January 14th, 2024 at 15:25, Martin A. Flynn via vcf-midatlantic<vcf-midatlantic at lists.vcfed.org> wrote:
>>> The AP9617 card does not have a separate serial Interface and the
>>> pass-thru serial port on the SUA2200RMXL3U does not respond to the
>>> factory defaults....
>>> On 1/14/2024 3:18 PM, Jameel akari via vcf-midatlantic wrote:
>>>> I would try to re-configure via the UPS’s serial port first. Default username and password are usually apc / apc .
