[vcf-midatlantic] AT&T 6386 WS keyboard db9
Hopkins, Justin
Justin.Hopkins at broadridge.com
Mon Jan 29 16:07:53 UTC 2024
It isn’t. the pinout and codes were unique to that keyboard, so any adapter would need to translate the codes. You would need to find a 6300 or Olivetti keyboard with the DE9 connector.
From: vcf-midatlantic <vcf-midatlantic-bounces at lists.vcfed.org> On Behalf Of Neil Cherry via vcf-midatlantic
Sent: Saturday, January 27, 2024 7:55 PM
To: vcf-midatlantic <vcf-midatlantic at lists.vcfed.org>
Cc: Neil Cherry <ncherry at linuxha.com>; vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org>
Subject: Re: [vcf-midatlantic] AT&T 6386 WS keyboard db9
AT&T 6386 WGS I don't think an Amiga keyboard will work. It's probably a standard AT keyboard interface. I'm pretty sure it's a standard Intel designed motherboard. I have one you can test with but I need it for my 6386sx WGS. -- Linux
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
AT&T 6386 WGS
Linux Home Automation Neil Cherry kd2zrq at linuxha.com<mailto:kd2zrq at linuxha.com>
https://urldefense.com/v3/__http://www.linuxha.com/__;!!Ebr-cpPeAnfNniQ8HSAI-g_K5b7VKg!PhTddbF57HynWIgjFIzVQlZl2iuX2F203TM8pZT-hpL8quaL9nVBIEDO5NytUZi9rbrEVAIHoGFvGdvoDp0GLeRZ-yrrBsBa93-May8$<https://urldefense.com/v3/__http:/www.linuxha.com/__;!!Ebr-cpPeAnfNniQ8HSAI-g_K5b7VKg!PhTddbF57HynWIgjFIzVQlZl2iuX2F203TM8pZT-hpL8quaL9nVBIEDO5NytUZi9rbrEVAIHoGFvGdvoDp0GLeRZ-yrrBsBa93-May8$> Main site
https://urldefense.com/v3/__http://linuxha.blogspot.com/__;!!Ebr-cpPeAnfNniQ8HSAI-g_K5b7VKg!PhTddbF57HynWIgjFIzVQlZl2iuX2F203TM8pZT-hpL8quaL9nVBIEDO5NytUZi9rbrEVAIHoGFvGdvoDp0GLeRZ-yrrBsBanbNPnVI$<https://urldefense.com/v3/__http:/linuxha.blogspot.com/__;!!Ebr-cpPeAnfNniQ8HSAI-g_K5b7VKg!PhTddbF57HynWIgjFIzVQlZl2iuX2F203TM8pZT-hpL8quaL9nVBIEDO5NytUZi9rbrEVAIHoGFvGdvoDp0GLeRZ-yrrBsBanbNPnVI$> My HA Blog
Author of: Linux Smart Homes For Dummies KD2ZRQ
This message and any attachments are intended only for the use of the addressee and may contain information that is privileged and confidential. If the reader of the message is not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any dissemination of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by e-mail and delete the message and any attachments from your system.
