[vcf-midatlantic] ADM3a parts at System Source March Workshop...
William Sudbrink wh.sudbrink at gmail.com
Fri Mar 8 17:22:35 UTC 2024
Hi,
I will be at the System Source Workshop on March 30,31.  I will be
bringing a bunch of ADM3a parts, including:
(Names are to help identify pictures, web site below)
Chassis1 - this blue chassis is an original, serial number 6961 with the
115 volt transformer.
Chassis2 - this blue chassis is a type 2 (with the extra venting and
cardboard interior), also 115 volts.
Chassis3 - this brown chassis is a late type 2.  It has no speaker (the
speaker was soldered to the mainboard in late type 2). This is a 230
volt transformer unit.  Its fuse holder and switch were donated to 115
volt machines a long time ago. Otherwise complete.
Clean board - this mainboard has no keycaps but is otherwise physically
complete and in good condition.  It powers up to a cleared screen with a
cursor but shows no activity on key presses.  Note that the key switches
are present on the board.
Dirty board - this mainboard has seen better days.  There is some light
corrosion on some chip pins and component leads.  It has some but not
all keycaps.  Definitely does not work as it stands. I got it this way
and only took it for the lower case ROM which is being used elsewhere.
Good monitor - well, good in that it works and has no visible burn in.
But... it has terrible cataracts.  It has not, fortunately, started
leaking.  Complete with driver board.
Zenith monitor - Has a little screen burn and a couple of scrapes on the
glass.  I have no compatible driver board for this monitor.
Mounting hardware - these mounting "ears" and band were taken from a
Ball CRT with a broken neck.  Could be used to mount a different CRT in
an ADM3a.
Driver1 - This is a complete driver board for a Ball CRT. Unfortunately,
the anode cap was smashed, but I am including a replacement that will
need to be installed.
Driver2 - This CRT driver board is incomplete.  It has had its HV
transformer taken.  I _think_ this is also for a Ball CRT but it is
different from driver1.  Could be useful for repairs.  Bracket for
mounting the HV transformer is included.
Pictures at: http://wsudbrink.dyndns.org:8080/images/adm3a/
Finally I, of course, would like some money for this stuff but more
importantly, I do not want to take any of it home with me!  I will deal
and if it gets late in the day and you're nice, you may take it home for
free.
Bill Sudbrink
This email has been checked for viruses by Avast antivirus software.
www.avast.com
