[vcf-midatlantic] ADM3a parts at System Source March Workshop...
Herbert Johnson hjohnson at retrotechnology.info
Fri Mar 8 22:01:33 UTC 2024
> Mounting hardware - these mounting "ears" and band were taken from a
> Ball CRT with a broken neck.  Could be used to mount a different CRT in
> an ADM3a.
Just a caution on that band - *do not remove band from an intact CRT*.
That metal band provides tension on the CRT against the vacuum inside
versus 15 pounds per square inch air pressure outside. Yeah, 15 pounds
per inch. If an un-banded intact CRT is struck and shatters, those glass
shards could be propelled like a glass grenade.
Most CRTs break at the neck, or the very tip at the neck. The neck is
thin glass. That narrow opening slows and limits the airflow to *into*
the CRT which otherwise has very thick glass. These CRTs were designed
decades ago with safety in mind.
A lot of small terminal and TV CRT's have a band and screw-mounts.
There's no need to fuss with that band. Reattach some other kind of
"ears" if needed for mounting in another TV or CRT. But I've taken TV
CRTs and popped them right into ADM3A's using the same ears.
regards, Herb Johnson
Herbert R. Johnson, New Jersey USA
https://www.retrotechnology.com OR .net
or try later herbjohnson AT comcast DOT net
