[vcf-midatlantic] AT&T 6386 WGS, Olivetti 380 computer, power supply schematic needed
CJ Reha
thedestructionchannel2000 at gmail.com
Mon Mar 11 01:45:11 UTC 2024
Something else I just thought of - your messages imply the computer was
working beforehand and just recently failed. This is a dumb question, but
have you checked the voltage rails on the board for shorts? I have had at
least one power supply come in for repair, and work perfectly on the bench
- the customer's computer had a shorted tantalum or something on the
motherboard masking as a bad power supply. I've been bit that way more
times than I'd like to admit as well.
Regards,
CJ
On Sun, Mar 10, 2024 at 1:30 PM Sentrytv via vcf-midatlantic <
> Good afternoon
> I believe I have posted before with a question about a keyboard for this
> computer (386-20),
> but now I have a question about a schematic diagram for the power supply.
> I am looking to repair the power supply which is currently dead, outputs
> about .5 V -.5 V and that’s it.
> Nothing obviously open or shorted. Somebody did have their hands in it
> prior to me, replacing or at least soldering various transistors.
> My issue is:
> I would like to find a schematic diagram for this so that I can do
> repairs myself.
> Or at the very least, connect an AT power supply or hook up an ATX power
> supply to get the computer running.
> I would need to know what voltages besides the obvious 12 V, 5 V , -12 V
> ,-5v needed to run this system.
> If anyone has experience performing such a task,
> Please contact me directly if necessary.
> I won’t bring it to the workshop unless I can find someone who knows, and
> I have a schematic diagram in hand.
> Thank you
> Mike Rosen
> Sent from:
> My extremely complicated, hand held electronic device.
