[vcf-midatlantic] 100ft ethernet cable needed for VCF East
Martin A. Flynn maflynn at theflynn.org
Sun Mar 24 23:36:00 UTC 2024
The Ethernet switch is in the 9032A furnace room, and the cable access
hole in the furnace room is only about 3/4" in diameter
Be aware whatever is supplied, the connector needs to fit through the
existing hole!!
On 3/24/2024 7:13 PM, Gregg Levine via vcf-midatlantic wrote:
> Hello!
> Jeff? Was your exhibitor successful in tracking down the needed
> lengths of Ethernet? That roll of 304.8 meters of Ethernet, terminated
> via 8P8C connectors is still available.
> Oh and the dino is off for next month visiting relatives in Utah and California.
> Gregg C Levine gregg.drwho8 at gmail.com
> "This signature fought the Time Wars, time and again."
> On Sun, Mar 10, 2024 at 11:20 PM Jeffrey Brace <jeffrey at vcfed.org> wrote:
>> David and Gregg,
>> It seems that the exhibitor might be able to supply the length of cable needed. I estimate it to be about 125 feet. Hold off and I will get back to you if they can't find it.
>> Thanks!
>> On Sun, Mar 10, 2024 at 3:23 PM Gregg Levine <gregg.drwho8 at gmail.com> wrote:
>>> Hello!
>>> I happen to have about 304.8 meters of Ethernet that are not doing
>>> anything. That should be perfect for your exhibitor. Now how quickly
>>> is it needed?
>>> Oh and if you're writing your response from InfoAge, be careful. That
>>> velociraptor is awake and currently cleaning out the kitchen in the
>>> bunkroom.
>>> On Sat, Mar 9, 2024 at 11:10 PM Jeffrey Brace via vcf-midatlantic
>>> <vcf-midatlantic at lists.vcfed.org> wrote:
>>>> I was able to get two 100ft cables through Martin, but I might need one
>>>> more for an exhibitor who desires it.
>>>> Is there anyone that has one that we can borrow for VCF East?
>>>> Thanks!
>>>> Jeff Brace
>>>> Vintage Computer Festival East Showrunner
