[vcf-midatlantic] 100ft ethernet cable needed for VCF East
Gregg Levine
gregg.drwho8 at gmail.com
Sun Mar 24 23:47:44 UTC 2024
Hello!
Mine is the one that's all of 304.8 meters, (100 Foot) and is
terminated correctly. (Well it's wearing the proper connectors.) I
believe one other has a roll of the stuff that can be setup
appropriately.... But I am not sure.
Gregg C Levine gregg.drwho8 at gmail.com
"This signature fought the Time Wars, time and again."
On Sun, Mar 24, 2024 at 7:38 PM Brian L via vcf-midatlantic
<vcf-midatlantic at lists.vcfed.org> wrote:
> I am that exhibitor that needs the 125' ethernet cable .. we thought one of our guys had a length this long, but we do not. If this is still available for our set up on Friday, it would be greatly appreciated.. It will be connected in the left/rear of room 9032A.
> Thank you,Brian
> On Sunday, March 24, 2024 at 07:35:25 PM EDT, Martin A. Flynn via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
> The Ethernet switch is in the 9032A furnace room, and the cable access
> hole in the furnace room is only about 3/4" in diameter
> Be aware whatever is supplied, the connector needs to fit through the
> existing hole!!
> On 3/24/2024 7:13 PM, Gregg Levine via vcf-midatlantic wrote:
> > Hello!
> > Jeff? Was your exhibitor successful in tracking down the needed
> > lengths of Ethernet? That roll of 304.8 meters of Ethernet, terminated
> > via 8P8C connectors is still available.
> > Oh and the dino is off for next month visiting relatives in Utah and California.
> > On Sun, Mar 10, 2024 at 11:20 PM Jeffrey Brace <jeffrey at vcfed.org> wrote:
> >> David and Gregg,
> >> It seems that the exhibitor might be able to supply the length of cable needed. I estimate it to be about 125 feet. Hold off and I will get back to you if they can't find it.
> >> Thanks!
> >> On Sun, Mar 10, 2024 at 3:23 PM Gregg Levine <gregg.drwho8 at gmail.com> wrote:
> >>> Hello!
> >>> I happen to have about 304.8 meters of Ethernet that are not doing
> >>> anything. That should be perfect for your exhibitor. Now how quickly
> >>> is it needed?
> >>> Oh and if you're writing your response from InfoAge, be careful. That
> >>> velociraptor is awake and currently cleaning out the kitchen in the
> >>> bunkroom.
> >>> On Sat, Mar 9, 2024 at 11:10 PM Jeffrey Brace via vcf-midatlantic
> >>>> I was able to get two 100ft cables through Martin, but I might need one
> >>>> more for an exhibitor who desires it.
> >>>> Is there anyone that has one that we can borrow for VCF East?
> >>>> Thanks!
> >>>> Jeff Brace
> >>>> Vintage Computer Festival East Showrunner
