[vcf-midatlantic] Old computer I can learn to repair?
Benjamin Krein
superbenk at gmail.com
Sat May 4 13:08:37 UTC 2024
Good points. Maybe this is a good time to build Ben Eater’s breadboard 6502?
Benjamin Krein
Sent from my iPhone
> On May 4, 2024, at 8:58 AM, Sentrytv <sentrytv at yahoo.com> wrote:
> Personally, I believe that you should learn the basics of the oscilloscopes how to set and configure, how to read and interpret the screen, and then how do use it in a practical application.
> If the scope does not have a built-in calibration tool, probably your best bet would be to either purchase, or even better, to build one, so the scope can be properly calibrated and you know it is accurate.
> Yes, of course the calibration source Has to be accurate.
> Once you’ve done that you can even start with an old handheld a.m. radio that runs off of a couple of AA batteries so that it is completely safe and use the scope to check waveforms while a signal is present and not present, just to get familiar.
> One of the things you may want to invest in later on and even now it is a MicroProcessor trainer, which you can easily use a scope on and will show you different signals.
> The Z 80 CPU trainers are fairly cheap.
> Mike
> Sent from:
> My extremely complicated, hand held electronic device.
>> On May 4, 2024, at 8:20 AM, Benjamin Krein via vcf-midatlantic <vcf-midatlantic at lists.vcfed.org> wrote:
>> Yeah, I'll learn what I can with the computers I have for sure. There is a
>> motivating reward to fixing something broken though so I thought I'd ask
>> around.
>> That o-scope tutorial kit looks interesting. I wonder if that'd be easy
>> enough to build with spare parts? I'm sure I can simulate plenty of
>> scenarios with various microcontrollers too. All good things I can & will
>> do but those still don't have the same reward of actually bringing
>> something real back to life.
>>> On Fri, May 3, 2024 at 10:17 PM James via vcf-midatlantic <
>>> I just bought this to help me learn how to use an Oscilloscope.
>>> https://www.jameco.com/z/WSEDU06-Velleman-Whadda-Oscilloscope-Tutor-Kit-Generate-Safe-Real-World-Signals-to-Measure_2175568.html
>>> I haven't used it yet, but it seems promising enough for the price.
>>> On Fri, May 3, 2024 at 9:00 PM Bill Degnan via vcf-midatlantic <
>>>> Ben,
>>>> You can learn a lot with a working computer. I would want to start with
>>>> something known-to-work.so you have control over those variables. To see
>>>> what a proper circuit looks like on a scope will be useful when you
>>> compare
>>>> to a non working machine
>>>> Bill
>>>> On Fri, May 3, 2024, 6:25 PM Benjamin Krein via vcf-midatlantic <
>>>>> I just got my first ever oscilloscope (Zoyi ZT-703s) but I have a
>>>> problem -
>>>>> I don't have any broken computers! :) Anyone have any old computers
>>> that
>>>>> are repairable they want to get rid of? Probably something 8-bit just
>>>>> because I'm an absolute beginner. I'm also thinking something more
>>>> common
>>>>> just because resources will be easier to find. Here's my wish list
>>> but I
>>>>> won't look any gift horses in the mouth!
>>>>> 1. Commodore 128
>>>>> 2. Atari 400(xl)/600/800(xl)
>>>>> 3. Apple IIc(+)
>>>>> I've always wanted an Amiga (500) but I'm not sure if that's getting
>>> too
>>>>> complicated or not for the scope I got?
>>>>> I'm in the Philadelphia area.
>>>>> - Benjamin Krein
>> - Benjamin Krein
